DIY NO DRILLING 2024 Tremor Modular Bumper 40inch light bar
mandronline
burbank california
2024 tremor
Made a step by step installation video for our Pro 40 inch light bar let me know what you guys think! I will tag on the light specs as well!
Fits 2024 2025 Ford F150 Tremor with Modular Bumper ONLY.
  • Curved LED light bar PRO
  • Light bar is made out of 304 aluminum. The surface is UV polyester powder coated to prevent against UV, salt water, corrosion, fading and scratch resistant. With a rating of IP68, the light bar is dust-tight and water-proof.
  • Perfectly follows the Ford Raptor bumper and grille factory curvature
  • Stays slim to the bumper for a sleek, built in look
  • Don't need to remove grille or bumper
  • No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware.
DUAL COLOR
Main White LED Light with Amber DRL (daytime running lights)
  • White LED -- Super bright and crisp white beam pattern. It will definitely provide you with enough light needed for all of your adventures. However, these are only for off-roading and can’t be used on the regular road. They will blind the in-coming traffic and also violates road safety.
  • Amber DRL -- amber DRL “daytime running lights” acts purely for aesthetics. Since it doesn’t give out much light, you can use this amber DRL feature on regular roads, it doesn't blind in-coming traffic.
Is there any chance you can piggyback the amber into the DRL and then only have the white switched?
Just to clarify, Did you mean to ask if the amber function on the light could be split off to another source? I don’t know how that specific light bar works, but I think it’s tied together.
I am not sure if youre asking if the amber function on the light bar can be turned on with the amber of the rest of the truck, in that case you can. You need to go into your fuse box and locate the ignition fuse section and splice the wire into them so that you can have the amber be turned on with the rest of the truck.
If youre asking if the white can be turned on without the amber DRL function being on then that is also a yes. the white and amber function are not tied together.
If neither of those answered your questions feel free to reach out! I will get to you as quickly as possible!
DUAL COLOR
How many Lumens is this Light Bar?
40in PRO Light Bar Specs
  • Theoretical max power 220watts
  • Actual power 125watts
  • Main White light is 10.42amps at 12v
  • Backlight Amber is 0.25amps at 12v
  • Theoretical max luminous flux 24,024 lm
  • Measured luminous flux (without lens) 15,224 lm
  • Measured luminous flux (with lens) 12,108 lm
  • LEDs type: luminus SST-20 Ra70
  • Temperature: 6000k
  • LEDs number: 22pcs
Thinking about getting one of these. Anyone on here have one? Looking for reviews
LOVE my lightbar! The quality is exactly what I hoped it would be... Amazing! Install was insanely easy and quick! The running lights match perfectly and give the truck an aggressive appearance. The high beam is extremely bright and looks awesome!
If your on the fence about getting one...all I can say is...JUMP!
Thanks for a quality product @mandronline
View attachment 40917View attachment 40916View attachment 40915View attachment 40923View attachment 40918
😂…..It’s smiling.
Looks badass! Thank you for the support!
Truck looks great in black.. I have those three grill lights and side emblem light sitting here in the box too thanks for the pics!
